Author Topic: These little black dip switches from Tayda are nice for prototyping.  (Read 664 times)
Offline JenniferGTopic starter
I just received my Tayda order and these little IC shaped dip switch clusters are nice.  They have normal IC pins, which are long and secure well into the breadboard unlike the red ones.   They are also much smaller, but with same footprint.
Great for prototyping where you perhaps need several low current toggle switches but are tight on space.
35 cents a piece from Tayda :
https://www.taydaelectronics.com/black-dip-switch-4-positions-gold-plated-contacts-top-actuated.html
(EDIT: looks like they just went out of stock on the 4 x DIP switch cluster.. they have 3 and 5 clusters in stock though.)
Here's a photo I just snapped of it in my breadboard.
« Last Edit: December 09, 2022, 11:31:12 am by JenniferG »
Test Equip: GDM-8251a, UT61E, Probemaster, Tektronix 2225
Power Supplies: GPD-3303S (w/o overshoot problem)
Soldering Station:  Hakko 926
Offline ledtester
Re: These little black dip switches from Tayda are nice for prototyping.
« Reply #1 on: December 09, 2022, 04:37:44 am »
Years ago I regularly shopped Tayda for stuff but lately I find myself browsing aliexpress more and more. I should check them out again and see what they got.
Also, it appears that you have 3D-printed some sort of "carrier board" for your stripboard and atmega2560 module. Is it anything like this:
https://www.amazon.com/GeeekPi-Raspberry-Holder-Breadboard-Arduino/dp/B07WFMV8FJ/
« Reply #2 on: December 09, 2022, 11:18:41 am »
Yeah Tayda is great for a lot of things. I really like their Royal Ohm resistors as the leads are nice and thick, great for breadboarding.
I'm using this, which I 3D printed at home:
https://www.thingiverse.com/thing:957376
I really like it and made a little system for it I call BLOCKS:  https://www.modwiggler.com/forum/viewtopic.php?t=267893
« Last Edit: December 09, 2022, 11:23:18 am by JenniferG »
The following users thanked this post: mikerj, ledtester
Offline mikerj
« Reply #3 on: December 09, 2022, 02:38:23 pm »
That's a genuinely neat idea, I'm going to print one out for myself.  I'm often struggling with a rats nest of eval boards and small stripboard hacks when doing early development at work.
The following users thanked this post: JenniferG
