Hi all! I am trying to build a switching converter that will take 16.5 - 48V and convert it to 15.5V with a maximum current of 16A. Yep, about 250W! I am still a beginner at this, so I am using TI's Webench design tool to help me. The tool doesn't find any solutions for me when I give it my requirements. However it gives me a single solution when I decrease the required output current to 10A. The solution is a synchronous buck using an LM5116 controller.
From some researching (and other forum posts), I have determined that to increase the current output, I need to
A) Use FETs with a higher switch current rating (Is this equivalent to looking for a lower RDSon?)
B) Use a higher switching frequency (downside: decreases efficiency)
C) Use a bigger inductor (Usually marginal gains in current)
I am thinking about taking the design that was generated for me by the tool and simply doubling up the FETs. Is this a good idea? Are there drawbacks besides increased cost?
Furthermore, does the controller care how much current is actually being delivered? Not that I would, but is there anything stopping me from using more and better FETs until I can get like hundreds of amps out of it? I'm assuming the only thing stopping me is gate capacitance?
Thank you!
