Following on from my posts here:
https://www.eevblog.com/forum/testgear/hp-4952a-protocol-analyzer-service-manual/I want to re-purpose this HP 4953A protocol analyser into something cool and retro game related. I've re-furbed the PSU, mapped out the keyboard matrix, and reverse-engineered the green phosphor 9" monochrome CRT monitor. It's a fixed-sync monitor, 60Hz vertical, 25kHz horizontal. It takes +5V, +12V, and four active-low TTL-level signals, one each for H and V sync, a pixel bit, and an intensity bit. The protocol analyser's CRT2 board has a 25MHz crystal on it, so I'd say the horizontal resolution is somewhere around or perhaps just north of 650-700px viewable (allowing 200px or so for retrace, front porch, and back porch).
The 25kHz horizontal refresh is too slow to display 480-line VGA signals natively (I'll get back to this later), but should be just right for 350-line EGA signals (with room to spare). My idea is to have a small vintage PC mounted inside the chassis with an EGA card, some simple double-buffering circuit, and a microcontroller circuit to interface with the keyboard.
So my question is: Is a FPGA (or maybe a CPLD?) the right tool to build a simple TTL video double-buffering circuit? Writing to the display from buffer A while buffer B is filled, then swap and repeat, it seems simple enough, but I don't know enough about CPLD/FPGA capability to say for sure.
I've seen barebones Altera Cyclone II dev boards on DealExtreme, and now seems like as good of a time as any to learn, but I want to know if that approach is going to work before I spend a lot of time learning Verilog or VHDL.
