Author Topic: basic transistor amplifier  (Read 1422 times)
Offline ykurbanTopic starter
  • Country: tr
« on: April 07, 2020, 02:04:56 pm »
How do you calculate gain of this simple amp?
Offline schmitt trigger
  • Country: mx
Re: basic transistor amplifier
« Reply #1 on: April 07, 2020, 02:09:14 pm »
Are you familiar with a bipolar transistor's h-parameters?
Since most resistors are well bypassed with capacitors, at a mid-frequency the circuit is reduced to a grounded emitter with a single collector resistor load.
Although you can calculate the gain of the stage by itself, for the actual gain you require to know the load impedance and the source impedance.
« Last Edit: April 07, 2020, 02:11:31 pm by schmitt trigger »
Offline graybeard
  • Consulting III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #2 on: April 09, 2020, 07:27:42 am »
If you can assume beta is large then the base voltage is:
VB = R8 / (R8 + R9 + R10 + R11) * 9V = 2.96V
The emitter voltage is:
VE = VB - VBE = 2.96 - 0.68 = 2.28V
The emitter current is therefore:
IE = VE / R12 = 84µA
since we assumed beta is large:
IC = IE
the transistor transconductane is:
gm = IC / VT = 3.36 mS
where VT = k * TK / q = 25mV
the mid band voltage gain from the base to the collector is:
AV = gm * R4 = 3.36ms * 2.2KOhms = 6.72
As schmitt trigger said the load and source impedances will alter this result.
« Last Edit: April 09, 2020, 11:49:11 pm by graybeard »
Offline duak
« Reply #3 on: April 09, 2020, 04:44:14 pm »
Graybeard, I remember doing those calculations in college and was able to determine the DC conditions.  I remember the next steps used IE and the 25 (or 26 mV) constant but not that it gave the transconductance.  Use it or lose it, indeed.
Offline graybeard
    • Chris Grossman
« Reply #4 on: April 09, 2020, 07:29:26 pm »
In my case it has been more than 30 years since I taught this as graduate assistant, but I still use it for work.
Offline bson
« Reply #5 on: April 09, 2020, 07:30:01 pm »
AV = gm * R4 = 33.6ms * 2.2KOhms = 67.2
Shouldn't this be gm * (R4 + R5 + R6)?
Edit: oh wait, nvm, I wasn't awake enough to note it's an AC property.  R4 alone leads to ground.
« Last Edit: April 09, 2020, 07:32:05 pm by bson »
Online xavier60
« Reply #6 on: April 09, 2020, 10:02:28 pm »
AV = 67.2 seems high. At college we were taught Re = 29/I, I in milliamps. We weren't told were the 29 came from.
Re = 29/0.084mA = 345Ω
 So I get an AV of 6.37.
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
The following users thanked this post: schmitt trigger
Offline graybeard
    • Chris Grossman
« Reply #7 on: April 09, 2020, 11:50:27 pm »
I slipped a decimal place in the quick calculations.  gm=3.36mS not 33.6mS
The following users thanked this post: xavier60
Offline vk6zgo
« Reply #8 on: April 10, 2020, 02:33:18 am »
I hate the complex looking bias circuit, although it is mainly just an artifact of the simulator rendition.
My first approximation for gain, just looking at the 2.2k load, was "Gain--- not very much!"
Luckily greybeard & xavier60 have "done the hard yards" so I didn't have to !
I remembered from back in the mists of time, "gm Rc" (actually, it was "gm Rp" when I first met it).
Offline graybeard
    • Chris Grossman
« Reply #9 on: April 10, 2020, 07:38:52 pm »
Only for pentodes and perhaps tetrodes.
Offline basinstreetdesign
« Reply #10 on: April 11, 2020, 02:28:27 am »
It has also been a long while since I did this but my calc agrees with greybeard.  6.7 looks right.
STAND BACK!  I'm going to try SCIENCE!
Offline vk6zgo
« Reply #11 on: April 11, 2020, 03:29:18 am »
Indeed, but transistors look more like pentodes than triodes.
