So I did some measurements and already blew up something
I soldered on some wires to the battery points to my DP832, and was working great. I saw power draw of almost 1Watt, so 250 mA. While I was trying to figure out how to do a histogram of the power draw, to see what the max was, I accidentally pushed 14V's. So I removed the HT36 which wasn't working anymore as it should (voltage wouldn't go above 2.65 V anymore) and shorted R1, which now makes sense, PCB reuse without a regulator
It still works somewhat, but not sure if I may have blown up the speaker coils a bit. Anyhow,
I don't really want to remove the transformer from my metering cabinet, as I have a very thin solid copper wire running through walls to where the bell will be placed. I'm not gonna run 230 VAC on these wires
So I'll always end up with 8 - 12 VAC as input.
So I could replace the transformer in the metering cabinet with a dinrail 5V supply (
https://denkovi.com/hdr-15-5-industrial-din-rail-power-supply-5V-2.4a-out for example) though voltage drop over those thin wires is probably not ideal. And again, I don't want to really change the metering cabinet
Also, I have no faith in those ali-express units for serious use :p and they are not DIN mountable.
So 8705 as an input to the LDO is actually not a bad idea. Will have to be a tiny SOT one of course, as I don't have that much space.
So from those measurements, if I get a 350 - 500 mW unit it should be fine, even if someone is 'spam calling' generally, power draw is minimalistic, and the audio playback only lasts for 5? seconds. So 5 seconds of heat shouldn't be an issue i reccon.
What about efficiency? 99.9% of the time, the unit will just idle (lets say 10mA for arguments sake) doing 15 VDC -> 5VDC. Negletable?
I'm lookinag at AMS1117-5.0
https://jlcpcb.com/parts/1st/Power_Supply_Chip_79853 which should be great, no?
Am I correctly interpreting the datasheet however, that the AMS1117 will only really do 100 mA, because 12 - 5 = 7 V?
