Author Topic: JLC SMT though hole components ?? - Do they actually mount them?  (Read 1714 times)
Offline Decee1Topic starter
« on: February 16, 2021, 12:49:33 pm »
Hello,
I was just researching assembly for one of my projects so i went and searched "Headers" in the JLCSMT library and found though hole components.
https://jlcpcb.com/parts/componentSearch?searchTxt=header
Anyone tried ordering a assembly with though hole components, do they actually solder them or are they just in the box so you can solder them yourself?
Specificly i found C124386 which is a Pin Header 8 2 Straight 2.54mm header which really caught my attention.
Stefan
Online coromonadalix
Re: JLC SMT though hole components ?? - Do they actually mount them?
« Reply #1 on: February 16, 2021, 03:25:44 pm »
At my job the thru hole connectors and other thru hole parts  pass thru an wave soldering machine, or we solder them by hand if needed ?
Offline Pr0cess0r
« Reply #2 on: February 17, 2021, 01:00:51 am »
I did not use it but juste made a pcb with come component and they charge a fee for those parts and a soldering fee per led so yes they install them by hand.
« Reply #3 on: February 17, 2021, 07:39:31 am »
Exactly!
I wrote to JLC yesterday just to be sure.
They started hand soldering service a short time ago.
That is just awesome!
Stefan
« Reply #4 on: February 17, 2021, 07:40:15 am »
Yes, but JLC SMT didn't give you access to that before. It is something all new they have added recently.
Stefan
Offline Pr0cess0r
« Reply #5 on: February 17, 2021, 12:01:27 pm »
Yes and I’m using easyeda and those pet will not show up in easyeda I have to go to the website and use the part number to make sur it’s available!
Offline phil from seattle
« Reply #6 on: February 17, 2021, 03:32:10 pm »
This is all very new.  I have yet to see a report from anyone who has used it.  I have a lot of questions. Is there a TH equivalent of the CPL file? Are there conventions for the center of a TH part (Kicad uses pin 1 of connectors, is that it?). A number of parts do not have an obvious center given in their datasheets - like USB connectors (even SMT ones).
When JLCPCB added the TH stuff, I asked about guidelines and they said they were working on them. Haven't seen anything yet.
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #7 on: February 17, 2021, 07:32:35 pm »
I didn't yet run an actual job by them, but I uploaded and fitted a PCB including a USB connector. They charge a fixed setup fee plus a fee per solder joint. I assume that they assemble those parts by hand.
« Reply #8 on: February 18, 2021, 12:36:55 am »
Yes, by hand for the TH parts, I believe.  Does that mean no additional information beyond BOM is needed?   Just make sure there is a clearly visible part designator on the PCB and they will do the right thing? Maybe I will try a simple board with a couple of different TH parts to see how it goes.
My point of confusion is how SMD connectors are done - by hand?  I don't see a center point in any of the SMD USB connector datasheets that I looked at. How does one provide a correct CPL entry for PNP?
Offline Pr0cess0r
« Reply #9 on: February 18, 2021, 01:24:15 am »
I added rj-45 jack using easyeda and it show in the 3d smd preview correctly so I guess if you use easyeda they will know where to place it!   For smd usb connector I don’t. See why it would not be placed by the pick and place and reflow soldered?
« Reply #10 on: February 18, 2021, 02:26:55 am »
Interesting. What's the LCSC part number?
