Idiv/Iref is the ratio between the divider current and the adjustment pin current. At low divider currents, the adjustment pin current contributes greater error with the higher impedance divider. The adjustment pin current could be as high as 4 microamps and vary about half of that over temperature. I do my calculations based on parallel divider resistance rather than Idiv/Iref ratio.
