Hi all!
I made a little i2c controllable buck/boost converter PPS.
Here's the specs:
22x52mm
-Vin 2.7 V - 36 V
-Vout 0.8 V to 22 V with 20-mV step
-Iout 5A
-Ideal for USB-C PD power input or output
-Over Current Protection
-Output overvoltage protection
-Output short-circuit protection
-Shunt with x20 amplified voltage for current measurement
-High efficiency ~97%
-Thermal shutdown protection
-Breadboard compatible
-Texas Instruments TPS55288 based
You can use the i2c interface to control Voltage, over current limit and response time, enable/disable, operating mode PWM/PFM, load discharge, cable voltage droop compensation, hiccup mode, short circuit indication...
Together with a microcontroller it makes for a nice little programmable power supply.
I'm planning to open source it, maybe crowdfund, and to do a small production run. I'd like some feedback from you all here. To improve the design, and get an idea if there would be any interest for it. And maybe at what pricepoint.
Thanks!
Beau
