Use 6.3 Vdc instead of 6.3 Vac......
This is a possibility, but I am concerned that the Fender replacement power transformer I intend to use will be able to handle it. Should be able to rectify and create 12.6/6.3V regulated from the heater winding. Would have to drop about 2.5V or so in the regulator, not sure if the transformer can handle the extra power.
I feel like that's kind of going backwards though...because the 60 year old design worked just fine on 6.3VAC!
Rectifiers, regulators, and additional capacitance were expensive so its a cost cutting measure to use AC on the heaters. But even with DC you should still maintain good grounding techniques to minimise any capacitive coupling.
Unless your tubes have bad heater/cathode leakage (which some secondhand ones may have), there is no need for dc heaters.
In this case, dc isn't a "cure-all", as leakage will still cause changes in tube bias with dc.
DC heaters for indirectly heated tubes were rare as hens teeth during the heyday of tube equipment, except in a few highly critical instrumentation applications.
Large Transmitting tubes had directly heated cathodes, & used ac with special balanced (centre tapped) filament transformers, & in later times dc filament supplies, but "Receiving" type indirectly heated tubes almost exclusively used plain old ac heater connections.
An exception was portable & other battery equipment, which mostly used directly heated tubes of the "1",& "3" prefix series like ID8, 1T4, 3V4, etc.
To someone who "cut their teeth" on the British "Mullard", & Oz RTV & H "Playmaster" series, then went on to work on PMG " type 3" amplifiers, some of the techniques used by Fender are a bit weird, so I have a bit of trouble getting my head around them.
Re: Tubes used with PCBs---
I've seen a lot of these "cooked" from the early days of phenolic boards.
FR4 material is better, but it still can deteriorate over time.
The heat source isn't due to high resistance in the tracks, it is the heater element in the tube.
Heat travels out via the tube pins, & associated socket, eventually causing damage to the solder connections.
Increased resistance of these joints causes voltage drops & associated heating, so the thing has a cumulative effect.
