Author Topic: Power Amplifier AB class  (Read 4802 times)
Online dzseki
  • Country: hu
Re: Power Amplifier AB class
« Reply #25 on: June 20, 2019, 07:19:27 pm »
imho any design that's mostly through hole and then gives up and uses surface mount on the bottom gets disqualified.
In the example above, designer could have used a couple tiny circuit boards to place the surface mounted stuff om them and then use a couple headers to plug them into the main board (like SIP packages, RAM sticks ) ... or just use through hole parts ... so the whole design could have been single sided ... there's plenty of room on the board to do something like that.
Not to mention the lack of heatsink mounting options (Screw holes, silkscreen etc), and the weird placement of those 4 resistors at the top right by the holes
IMHO bending TH resistor legs is PITA, soldering SMD foil caps also PITA.
Also, I don't know do you complain about the heatsink, the designer clearly did not intend to install the output transistors on the PCB, but on a separate heatsink with flywires.
HP 1720A scope with HP 1120A probe, EMG 12563 pulse generator, EMG 1257 function generator, EMG 1172B signal generator, MEV TR-1660C bench multimeter
Offline strawberryTopic starter
  • Country: lv
« Reply #26 on: July 01, 2019, 06:14:23 am »
final PCB layout
