Author Topic: PCB voltage insulation  (Read 3792 times)
Offline tekman11Topic starter
« on: May 08, 2015, 01:03:06 pm »
Is it expectable to run a low voltage trace on the inner layer. the top/bottom carries AC max 275v.
The low voltage trace is routed on ground plane.  the power plane is un-routed.
I'm concern about arcing between top and ground layer.
The PCB stack up: top, gnd, power,  bottom.  The distance between top and ground is ~28mils.
The two layers are separated by prepreg. The construction is FR4.
 thanks
Offline Rerouter
Re: PCB voltage insulation
« Reply #1 on: May 08, 2015, 01:17:27 pm »
I went digging, and accounting for aging effects, FR4 still has a dielectric breakdown voltage of 300V per mil, so would seem you are fine to do so,
http://www.magazines007.com/pdf/High-Voltage-PCDesign.pdf
Offline Zero999
  • 0999
« Reply #2 on: May 08, 2015, 06:40:50 pm »
Don't forget that in order to comply with the regulations for reinforced insulation, it must be able to withstand much higher voltages, up to 6kV if I remember rightly, so 28 thou is probably the minimum thickness.
I hope you're also aware of the creapage and clearence requirements.
