Mine runs at 70kv (though it's supposed to be switchable to 60kv) at 7ma. It's a Siemens Heilodent MD, pretty standard dental xray head from what I can tell. I'll see about testing it opposite the sheet here in a bit, I finally got a replacement geiger tube and I'm about to get everything setup to do some leakage measurements, so far I've just been controlling it from another room (like they are used in a dental office). I use a D7000 with the IR remote, so I have to go back to it to check the images and whatnot, if the leakage is low enough it'd be nice to be closer to the unit so I can work through things faster. It's not necessarily the xrays harming the camera that I'm worried about, but it's the noise messing up the image. While post processing can remove most of the blemishes, it's more work the more hotspots there are.
