The unboxingI ordered a 10 position switch for a project expecting a normal sized switch. I did not check the scale the item and ended up with this beast! I was trying to figure out what the box was for and and ended up with a switch that fill my hand. It's got some weight to it too.
My initial impression is that it's used but still in great shape. The action is REALLY satisfying, it's got a good cur chunk to it.
Rear of switchFrom the number of wires I'm guessing it's a 2 pole switch. The wires are still in good shape and it looks clean here too. The screws holding on the rear mounting bar were in threaded inserts surprisingly enough.
With front dial removedThe front dial was held on my a large flat head screw and indexed onto the shaft with the rod seen here.
The reason for the satisfying feel is now apparent. The spring pushes the ball against the grove in the front dial. For a simple system it works really well.
Inside of the switchNow that we are in we can see the REALLY beefy contacts in side. The huge copper leafs are angled on the contacts to get the most contact area. They are doubled up as well. There's a second leaf under each of the ones you can see here.
Even after all these years it still moves smoothly. I imagine this thing can handle tons of current.
The screws holding the case together used threaded inserts same the the back. They really spared no expense. I would love to know who made it and how much it cost but I can't even recognize the logo.
10/10 Best impulse purchase ever. It was only ~16$ after shipping too!
TLDR: I love big knobs and I can not lie.
Any one have any idea who made this? Or where to find more?
Full Size Album
