Here's the situation - we have old design board that uses a 1Mx8 EPROM and we want to replace it with a more modern 5V flash device. On-board programming is not an option at this stage. Would enormously complicate things and set us back a long time. The current path of attack is to draw up a small board with the flash mem on it and plug it straight into the EPROM socket. So far so good. If we want to use the programmer on this small board though, the flash device pinout that the programmer socket would present doesn't match the original EPROM pinout that the small board would have so we can't just plug the small board straight into the programmer. Is there some way, or is there someone here skilled enough to devise a way to make this happen?
