If I follow the chinglish, that module although rated for 5A max, is only rated for 3A continuous output current. That would be pretty marginal if not overloaded when running a marine VHF and a plotter/fishfinder. When transmitting at 25W, the VHF alone is likely to pull over 3A. e.g. my old ICOM M56 pulls 5.5A @ 13.8V when transmitting.
The *ONLY* way this would work would be if the average current of the VHF on receive + plotter/fishfinder is less than 3A and you can figure out the differences between the module you have and the similar one with a current limit pot and convert it to add a 3A current limit. Then you could set it up to float charge a 12V 7AH SLA battery at 13.8V off the main battery, which would provide for the much higher transmit current and also give you a reserve for emergency comms if the main battery is flattened by binge poumps, cabin lights etc.
I suppose you could use it for just the plotter, but it is likely to be less spike resistant than the plotter is, and without some sort of clamping circuit or a battery on its output, you are betting that it will die quietly. If instead it looses regulation as it dies, it could easily stuff over 20V into the plotter for quite a few seconds before its fuse blows. Since you need the clamping circuit anyway, you might as well leave out the DC-DC converter . . .
IMHO, save it for something non-critical its actually good for like dimming cabin lights!
