You know actually it looks like that stamped heat sink has quite a bit of surface area, I was thinking maybe it might be close to the performance of the other one.
Just the problem is that when you put that one on, its pretty tight, you want to leave it on, it does not remove easy like the stamping.. it has the potential to start tearing leads if I do experiments
maybe I should do a junk box experiment to see if I have a dummy to39 device to heat up
its actually not super obvious to me which one has higher thermal performance. I feel like it might just go either way lol
the biggest thing, I think one of em is made from... spring something, and the other is aluminum. No matter how fancy you can make a springy heat sink in terms of dissipators.. i wonder if its spring copper or magnetic. if its magnetic i am putting my money on the aluminum.
and it turns out the springy one is non magnetic.
What the hell is it made out of? its silver under neath. Spring aluminum? I thought it would be too likely to crack. what metal could that be?
I am just gonna use themral greased extruded aluminum heatsinks instead of the mystery spring sheet heat sinks unless someone offers critical information within 2 weeks when the boxes are gonna be reassembled and tested
