Hey.
The other day i was watching all these X-ray videos and all that and got interested in these geiger counters. I looked at the prices and don't feel like spending money right now ( tight budget ! ).
So i naturally looked up a way to make one but most of them used this high voltage tube, but some others used this simple " aluminum tube with a copper wire inside " sensor things inside, i thought i might try to make one, maybe test it by pointing it at my big old CRT TV to see if it works.
Yet i don't know if those aluminum tube things really work, maybe any of you guys have seen/tried/heard of those kind of "sensors".
From what i know the "rays" are supposed to hit the tube and ionize some electrons (?) which then hit the copper wire that is inside and would display as a voltage across the outer aluminum tube and the copper wire inside.
My idea is to make a simple opamp circuit to sample the tiny voltage that came out of the tube and the output of the opamp would power a little " BJT with negative resistance " kind of oscillator which would make little " crackling " noises, through a small speaker indicating the "radiation".
But that's just me yapping about
I'd like to hear something from people who are more experienced in this type stuff.
Of course some help would be appreciated.
