not really enough info there - a particular ambiguity is "AC"
do you mean "a load for Spice .AC analysis"? in which case you need to recognize, allow for the special conditions of 'Spice .AC analysis: linearizing a circuit about and operating point - no detailed simulation beyond operating point is done so many nonlinear circuits/components like rectifier diode bridges don't give very useful results in .AC analysis
if you want to model the AC mains then a 50/60 Hz sine Vsource with maybe ~1 Ohm series resistance is a start, then model the load as closely as wanted out of standard parts, run a .TRAN analysis long enough to reach steady state...
