Author Topic: axial capacitor support structure?  (Read 846 times)
Offline coppercone2Topic starter
« on: November 18, 2023, 06:40:25 am »
Is there a generic round part support structure for axial components that is a partial circle as hardware you can buy?
and does anyone know maybe a parametric program for 3d printer prints? I want to center the axial caps in my project box. The 30uF one is heavy, and the 220nF one has tiny leads !
This was supposed to be a 1 minute project and its already  >:(
I guess its kind of like a zip tie holder. Maybe a double zip tie holder that is good enough can be found.
If anyone knows a good zip tie clamp that would work, or a series of them....
« Last Edit: November 18, 2023, 06:46:21 am by coppercone2 »
Online moffy
Re: axial capacitor support structure?
« Reply #1 on: November 18, 2023, 07:43:09 am »
As I mentioned in your other post about Teflon caps, at Ferranti we used large axial capacitors that were cable tied to a double thickness pcb and wedges were epoxied either side of the capacitor. It was reliable enough for fighter aircraft. :)
« Reply #2 on: November 18, 2023, 08:02:36 am »
The best I found is this
https://www.digikey.com/en/products/detail/panduit-corp/ABMT-A-Q/810899
There may be a better size, I don't have the patience to go through them right now. But if you put a bit of silicone rubber under the cap, it should sit nicely.
Offline Vovk_Z
  • Country: ua
« Reply #3 on: November 18, 2023, 10:55:16 am »
If you don't believe in one zip tie you may use two zip ties. Just drill holes for them. Otherwise you have to tell us more about conditions.
« Reply #4 on: November 18, 2023, 10:57:02 am »
the thing i found is pretty close but its not dedicated for components, two separate holes for each zip tie would be nice. if there was a series for different part diameters it would be sick
i usually hope people enthusiastic about the topic will add extra information not hyper specific answers
