Author Topic: Designing extremely low current voltage detectors  (Read 2122 times)
Offline pyrohazTopic starter
    • Harris' Electronics!
« on: January 08, 2015, 04:34:43 am »
Hey all,
I'm wondering how rechargeable battery powered electronics manage to cut off the battery from the circuitry to prevent overdischarge. I've designed a really simple low voltage detector with a tune-able cutoff voltage set by a potential divider. Obviously, the accuracy is pretty poor, its device dependent and temperature dependent so I'm wondering how this is generally done? I'll attach a pic of my sim if anyone is interested!
Cheers,
Offline TerraHertz
    • It's not really a Blog
Re: Designing extremely low current voltage detectors
« Reply #1 on: January 08, 2015, 04:50:42 am »
Search for 'lithium cell protection' and '18650 discharge protection' on ebay. Lots of cheap examples for reverse engineering. Or just to use as-is.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: January 08, 2015, 11:45:33 am »
Typically using extremely low bias comparators, which due to their low current, operate extremely slowly (~10us for the fastest ones, up to ~ms).  They are internally constructed with MOSFETs, gigohm resistors and CMOS logic.
The biggest challenge in designing such circuits is getting a reliable voltage reference.  The traditional bandgap reference, as with most circuits, exhibits noise proportional to sqrt(I).  At low currents, shot noise dominates, meaning, the voltage fluctuates up and down in rather huge steps (~mV?).  For a battery monitor, this makes it very difficult to precisely gauge state-of-charge and cutoff.
Trying to build a discrete version is kind of silly, because you need that low noise reference at some point.  Constructing a bandgap from discrete transistors is impractical (too temperature sensitive), and may not have good results anyway (a 2N3904 is probably 10,000 times larger than the transistors used for internal references, so the current density will be extremely low, and therefore hFE will be poor).  Using a commercial micropower reference is kind of cheating (it's an IC, so why not add a few more internal transistors for one of those ref-comparators or full on monitoring chips), and not quite good anyway (often, the comparison itself will be accomplished by monitoring when the bandgap turns on -- this is how many voltage regulators, like LM317, operate, using the reference as the error amplifier).
Seven Transistor Labs, LLC
« Reply #3 on: January 10, 2015, 02:18:19 am »
That's very well explained! Thank youf or your time.
I had a look on aliexpress to find out how the ultra cheapies do it and there seems to be a magical protection chip called the DW01 which when used in conjunction with a dual mosfet IC, you have a battery protection circuit! Thanks!
