Author Topic: TPD12S016PW HDMI ESD & RPi Compute Module  (Read 1006 times)
Offline SgtSiffTopic starter
« on: February 05, 2019, 08:52:58 pm »
Is anybody able to give feedback on the following schematic please?
I'm trying to design an open source CM3 prototyping board that has hand solder friendly components, so I'm hoping to replace the BGA ESD5384 with a TSSOP TPD12S016:
I have pulled LS_OE and CT_HPD high via 10K resistors, I believe this should disable any power saving and ensure the i2c lines are pulled up appropriately.
As far as I can tell, HDMI_HPD on the CM3 is active low, so I have used a mosfet inverter for this (in line with the original schematic).
My main concern is the CEC line, I'm not sure what to do with it and I'm not sure what the function of Q3 is in the original schematic:
Datasheet for the aforementioned ESD IC:
http://www.ti.com/lit/ds/symlink/tpd12s016.pdf
http://www.ti.com/lit/an/slla324/slla324.pdf
Thanks!
« Last Edit: February 05, 2019, 08:54:32 pm by SgtSiff »
