Author Topic: TPS2113A vs TPS2115A  (Read 853 times)
Offline petersanchTopic starter
« on: October 13, 2020, 03:51:31 am »
Anybody know what's the difference between TSP2113A and TPS2115A? The comparison on the TI website and the datasheets look like pretty much identical. Is one recommended over the other?
Cheers
Offline NiHaoMike
    • Facebook Page
Re: TPS2113A vs TPS2115A
« Reply #1 on: October 13, 2020, 03:57:44 am »
You have to open the datasheets and carefully compare them to find the difference. It's probably something small like the polarity of a control line or one of the detailed specifications.
« Reply #2 on: October 13, 2020, 04:05:02 am »
With taking a closer look. The TPS2113A has VSNS pin "An internal power FET connects OUT to IN1 if the VSNS voltage is greater than 0.8 V". TPS2115A has a different mode for that pin.
Maybe that helps someone in the future
