Author Topic: Choosing a power entry connector  (Read 1782 times)
Offline LukeWTopic starter
« on: August 03, 2016, 06:34:12 am »
I'm trying to choose a power connector. Any recommendations?
- 24VDC, 2A max.
- 2 pins (V+ and Gnd)
- Cheap is good.
- PCB mounted, right-angle, will poke through a plastic housing but does not have to be mechanically held onto the plastic.
- Must have some sort of clip or lock, cannot be pulled straight out.
- Typical "barrel" power connectors are therefore no good.
Offline prasimix
  • Country: hr
    • EEZ
Re: Choosing a power entry connector
« Reply #1 on: August 03, 2016, 07:12:27 am »
Perhaps Molex Mini-Fit Jr.? Latched, 4.2mm raster up to 13 A, 600 V.
As cheaper then genuine crimping tool a PAD-12 could be used.
Offline DutchGert
« Reply #2 on: August 03, 2016, 07:45:29 am »
Offline ajb
« Reply #3 on: August 03, 2016, 11:34:11 am »
Or the Wurth clone (MPC3), a lot cheaper. I use them all the time.
http://katalog.we-online.de/en/em/MPC3_3_00_FEMALE_SINGLE_ROW_RECEPTACLE_HOUSING_6620XX013322?sid=8687082314
Those look to be clones of the Micro-fit (3mm pitch) rather than the Mini-Fit (4.2mm).  I might be hesitant to use connectors like that due to the difficulty of providing suitable strain relief to the entering cable.  If this is an internal component or something where the connector isn't exposed to the cruel outside world it could be fine, but I'd be concerned about anything that might get rough handling.  Without a shell that firmly grips the overall cable, the crimp terminals will have to bear ALL of your mechanical load.
Switchcraft make barrel connectors with threaded locking nuts that are pretty nice, but not sure if there are PC mount jacks for them.
Maybe mini XLR? Or regular XLR if you've got a lot of space to burn.  Switchcraft TRA3M connectors are rated 5A.
Offline prasimix
  • Country: hr
    • EEZ
« Reply #4 on: August 03, 2016, 11:54:41 am »
That's good point ajb. It's not the same if connector belongs to internal or external wiring. I suggested Molex for internal (inside enclosure) application.
Offline ConKbot
« Reply #5 on: August 03, 2016, 02:37:51 pm »
Switchcraft 767K on the cable mating to a switchcraft L722RA PCB mount connector?
http://www.switchcraft.com/Documents/NPB%20575%20-%202.1mm%20plugs.pdf
Uses a 2.1mm plug, good for 5A, locking ring to secure it.
