Just taking an educated guess, but the "totally enclosed" type might offer better protection against dust ingress, but be slightly thicker and/or have weaker springs as a result, while the "open frame" type allows weakend springs to be repaired with gentle pressure, at the expense of allowing more dust ingress.
Regarding dust ingress, that kind of makes sense, but then again most of the time these connectors are inside an enclosure, so dust ingress isn't so much of a factor, surely?
I did think maybe that the one with external springs is perhaps rated for more insertion cycles, or more secure insertion, but according to the datasheets of the two examples I previously posted (
internal and
external) they are both rated for 3000 cycles, and the insertion/removal force is the same. The only difference I see is that the internal one is rated for 5A vs. 3A for the external.
Maybe the external kind has lower shield contact resistance, or more reliable shield contact, for better EMC performance?
