Dear forum members,
I bought a Symmetricom XL-DC. However, after connecting the antenna and switching on the device, the left display shows an A and unlock. The device is now on for over 24 hours and the antenna is in front of the window. I have checked if the antenna voltage of 5 Volt is present. The antenna I use has the following specifications: Frequency 1575.42 MHz +/-2 MHz ; Impedance 50 Ohm; Voltage 3V~5V. Does anyone have an idea what I am doing wrong. Thank you in advance. Evert
