Does anyone know of a simple circuit to trigger a 12volt relay, with the output voltage of an adjustable supply reaches a preset voltage.
Basically, I have a centre tapped 9+9 volt transformer, and wish to use the first tap when the output voltage is below ~10volts, and switch to both taps in series above this.
Thanks!
