Author Topic: non isolated power supply breaking buck converter.  (Read 1349 times)
Offline JnationTopic starter
« on: June 15, 2016, 08:12:26 pm »
Hello all, I am having an interesting problem, and cant seem to figure out whats going on.  I am designing a circuit (arduino clone that powers a small or large dc motor, schematic attached) that uses a dc/dc buck converter (digikey part# BP5277-50-ND). When I'm powering the device with my bench top power supply, or an isolated power supply I have no problem.  However once I use a Mean Well GS160A24-R7B  power supply (24V 6.67A 160W Max) it destroys the buck converter! The only thing I have noticed is that when I use my fluke to check polarity, the ground output of the Mean Well power supply is connected to mains ground which tells me its not a isolated power supply.  I'm going to switch to a isolated power supply, but I would still like to learn why this would break the buck converter.
Any help would be greatly appreciated!
-Jim
Offline uncle_bob
Re: non isolated power supply breaking buck converter.
« Reply #1 on: June 15, 2016, 11:23:52 pm »
Hi
All wall wart style supplies that are not "medical" have a common ground. That's just the way they do it. The ground is not your problem unless there is a sneak path. Best guess, you are not holding off the startup of your converter long enough or you do not have big enough input capacitors on the converter.
Bob
« Reply #2 on: June 17, 2016, 04:56:48 pm »
Thanks so much! I attached a 47uF and a 1uf ceramic capacitor to the input voltage of the converter, works perfectly now. :-+
Thanks again,
-Jim
EDIT* I was using a micro symbol, however they posted as ?  so i replaced them with a u.
« Last Edit: June 17, 2016, 04:58:28 pm by Jnation »
Offline uncle_bob
« Reply #3 on: June 17, 2016, 05:05:57 pm »
Thanks again,
-Jim
Hi
The *input* capacitor requirements for switching supplies are something that messes up a *lot* of people. First time through, nobody ever expects it to be an issue.
Bob
