Take a typical pcb mounted, sealed transformer something that looks like this:
What is a reasonable assumption for it's short term power capability?
Let say it has a nominal data sheet rating of 24v, 1amp output ie 24VA
1) I assume that is it's continuous rating in the hottest ambient it is rated for?
2) How much current could i expect to pull for say 30 seconds, 10 seconds or 5 seconds?
I have an application that mostly, requires about 500mA, but occasionally (think around once every 5 min or less) requires up to 2 amps for a max of 10 seconds. Is it foolish to assume the transformer could support twice it's rating for that short period with the large gaps in between?
(at the moment, i'm not worried about the voltage sag under those high current conditions, but obviously that is also a consideration. Critical stuff is powered from a 5v supply via a switch mode dc/dc, so the output can drop a LONG way before any issues.
The duration of the high current is really just a bit too long to buffer with a large amount of capacitance, but some capacitance will obviously help level the load a bit.
Anyone have any experience in establishing these sorts of ratings?
