Author Topic: Output of AC/DC Converter?  (Read 190 times)
Offline hal9001
« on: April 28, 2021, 10:13:25 am »
Is the output of AC/DC board mount converters regulated at constant voltage?
For example the datasheet of CUI PBO-15C has load regulation specd but Im not clear if that means the output is regulated.
Thanks
Offline Zero999
  • 0999
Re: Output of AC/DC Converter?
« Reply #1 on: April 28, 2021, 11:29:04 am »
The load regulation is the % change in output voltage, normally full load vs unloaded. For example, if the output voltage is 10V and the load regulation is 1%, the maximum change in voltage, between full and no load, is 10*0.01 = 0.1V.
In short, those AC:DC converter board are regulated. Another sign of this is the wide input voltage range. Unregulated converters specifiy a tight input voltage range.
The following users thanked this post: hal9001
Offline hal9001
« Reply #2 on: April 29, 2021, 07:05:17 am »
Thanks for the clarification
