I've had a little project on the back burner for some time - I've been meaning to write up a whole bunch of little useful electronics calculators - not just like the little ones you see scattered around that are no more convenient than a pocket calculator - and put them in a collection online. (My favorite so far is a voltage divider calculator that can do arbitrary series/parallel networks, multiple taps, etc, has different ways of specification - voltages at different points, ratios, decibels attenuation, and so on, and computes the best E-series values.)
If I ever get it finished, do you mind if I borrow some of the equations from your spreadsheet as part of the transistor bias calculator? With proper attribution, of course!
