Electronics => Projects, Designs, and Technical Stuff => Topic started by: RonFred2 on May 01, 2021, 09:19:24 pm
I recently crafted a transistor curve tracer with my Oscilloscope and Arbitrary Waveform Generator. Most BJT Si transistors show typical/normal traces but one device undertest produces abnormal trace when collector-emitter voltage (Vce) goes higher than about 6 Volts.
Does anyone know what is the cause of this abnormal trace?
I present a few images below showing my test setup, a good trace, and the weird trace.
http://www.biophysicslab.com/2021/04/27/testing_transistor_hfe/#measure-hfe-using-an-oscilloscope-and-arbitrary-waveform-generator-awg (http://www.biophysicslab.com/2021/04/27/testing_transistor_hfe/#measure-hfe-using-an-oscilloscope-and-arbitrary-waveform-generator-awg)
I suppose it's not inverted as hFE looks reasonable. Just defective then?
Negative resistance is normal avalanche operation -- but this normally occurs between Vceo and Vcbo, over 60V for 2N3906.
Tim
Someone on another forum had this to say about this circuit and transistor behavior, with one other person agreeing...
Looks like the CE junction got zapped and acts as a SCR with a negative incremental resistance . Might be good for a tunnel diode oscillator at RF if biased at -7V.;)This is a breakdown arc failure with say 40K/mm might be 40V/um so 7V is about a 175 nm gap that the E-Field bridged This PNP should be good to -40V and act like a Zener near -50V.
I thought this contribution may help others who look at this issue as well.
Thank you all for looking at my forum post here.
