Hello,
Just looking for way to minimize power loses on transformer secondary full-bridge rectifier.
I do not know if someone tried something like this:
Idea is to add in pararell to small full-bridge rectifier diodes (up to 5A) ... mosfet switches with optoisolated gate drivers and simply detect higher currents than 1A using Hall sensors and switch ON mosfets in pararell with conducting diode to have voltage drop not 0.5V-0.7V, but.. in the case of IRFZ44N mosfet with RDSON 0.018 Ohm @ 25*C and current 25A we have about 11 W loses in mosfet switch, while diode with 0.7V voltage drop has about 17 W lose.
Difference is much bigger when we use not 1 mosfet but much more depending on desired acceptable power loses, while when 2 mosfets are used than those loses in one rectifier switch will be about 5W, so in whole bridge about 10W, while when only diodes used and 2 of them conducting about 35 W and we can do nothing with this.
I do not saw such solution so far, maybe I've made simple mistake, but simulation shows it might work, while mosfets with internal diodes looks like can of couse rectify AC voltage and when synhronized switched on it looks like I should have in practice power loses limited only by number of pararell mosfets used
What do You think about adding or replacing diodes in full-bridge rectifier with mosfets with internal diodes?
Maybe no fast Shottky diodes needed, while it is only 50Hz AC current rectified, but I'm interested in higher rectified DC power above 250W and maybe at lower voltages around 14V in 3 phase full-bridge rectifier configuration, so current might be up to 50A I guess.
BTW: I've succesfully calibrated today another current sensor designed for 25Amax currents based on analog SS495A Hall sensor and it is quite cheap and easy detect currents >100mA regardless of its polarity (direction in which current flow) with galvanic isolation, so it looks like I have everything needed to test this thing which is very interesting to see how it performs in real higher power application if it can work at all
