I'll look at whether I already fixed that resistor error on my schematic. Not a big deal, however, if I'm asking for help on this forum, I'll waste the time of others if I'm posting incorrectly drawn schematics. Also, it brings down my credibility if I'm posting inaccurate stuff.
As you can imagine, I spent many hours tracing just to get that small schematic. I feel lucky to get the amount traced that I did. I'll admit, the schematic didn't make much sense and questioned my tracing, but I also didn't know anything about the hybrid.
Prior to buying the scope from someone, I was told about the broken channel 2 and 3, and if a voltage exceeds a certain DC voltage (some reason 5v comes to mind) is on the input while in 50ohm mode, the channel will blow up. At that point I was deathly scared of damaging the two good channels.
Unfortunately I'll never know how channel 2 and 3 got damaged. Upon hearing about blowing up the channels due to high signals, I assumed they were sensitive and poorly designed. Seeing that the G21 in those two broken channels had a sideways 32, measured differently out of circuit, and that a G21 can vary in part type across different manufactures, I wonder if someone injected a high powered signal, blew up the original G21, replaced it with the wrong type, and blew up the hybrid as a result.
You seem to have extensive knowledge about the hybrid functions. I searched for some theory of operations, or any information on the hybrids, but never found anything.
I believe my Digikey order is arriving today. Although I used Kapton tape to hold the components while using the hot air pencil, it managed to blow off a 1k resistor when I was replacing the hybrid in channel 3. I'm uncertain if I'll install the 1k resistor today or tomorrow, but, at after that, the scope will just need the new BAR63 in channels 2-4. Although I've powered it without these installed already, maybe I'll hold off until I get the BAR63s and install them.
Do you happen to know what the other digits in the part number represent in: BAR6304E6327HTSA1
The datasheet only seems to explain the BAR6304 part, but I don't know what the E6327HTSA1 mean. Digikey has more digits after, however, it's just tape and reel, cut tape, etc...
Most likely I don't need to worry about those numbers, but thought to ask just so I can know what I'm ordering.
