The RCA 3N200 is a n-channel MOSFET. It is a depletion type, i.e. a self-conducting MOSFET. According to the datasheet, the maximum permissible blocking voltage is 20V. The drain current must not exceed 50mA. The 3N200 is advertised for applications with frequencies up to 500MHz. At 400MHz, an amplification of 12,5dB would typically still be possible.
The datasheet shows that the gate electrodes have an overvoltage protection. As the 3N200 is a depletion type MOSFET, additional antiserial diodes had to be integrated. This is the only way to set the gate-source voltages to negative.
The RCA Application Note AN-4018 contains a somewhat clearer circuit diagram of the 3N200 and also shows the structures on the silicon. The simplified cross-section shows how the MOSFET works. Gate electrodes 2 and 1 comprise the drain area in the middle, followed by the source area. Heavily n-doped areas form both the drain and source areas, as well as the transition zone between the gate areas.
Two p-doped elements in an n-doped well form the antiserial diodes, which serve as overvoltage protection for the gate electrodes. A p-doped shield is shown between the MOSFET structures and the protective diode wells, which ensures that the two areas always remain isolated from each other. Otherwise it would be possible for conductive channels to form due to potentials applied above them or for parasitic bipolar structures to become conductive.
The cross-section conceals the fact that the substrate is connected to the source potential. This connection requires additional insulation measures for the protective diodes. This can be seen particularly clearly in the large metal area above the protective structures of gate 1, where the underlying contours can be seen. The square structure in the right-hand area shows a contact (smaller square) and a p-doped area (larger square). There is an n-doping in the neighbourhood, forming a diode. The same structure can be found with a slightly more elongated shape in the bottom left-hand corner of the area. This is the second diode. The area with the two diodes is not directly embedded in the substrate. The contours show two additional frame structures, the outer one of which is connected to the source potential.
In the package, the source pin is connected directly to the metal can.
The dimensions of the die are 0,63mm x 0,61mm. The structures correspond to those shown in the application note.
In the upper area, a few squares show how well the masks are aligned against each other. The structures of the protective diodes are also clearly visible here in the metal surfaces.
https://www.richis-lab.de/FET46.htm
