Author Topic: Transistors - die pictures  (Read 22223 times)
stevelup and 1 Guest are viewing this topic.
Offline graybeard
  • Senior III-V RF/mixed signal/device engineer
    • Chris Grossman
« Reply #50 on: June 03, 2020, 07:13:10 pm »
Great photos!
Undesired recombination at the Si SiO2 interface will produce IR. That IR emission is used to find trouble spots.
Standard recombination in GaxAl1-xAs produces quite a bit of light since the dominant mechanism is optical emission.  The color typically ranges from IR to red depending on the composition.
Light emission due to avalanche  breakdown in GaAs is typically green.
« Last Edit: June 03, 2020, 07:18:27 pm by graybeard »
The following users thanked this post: Wolfgang
Offline Noopy
    • Richis-Lab
« Reply #51 on: June 03, 2020, 07:28:45 pm »
Thanks!  :-+
SiC glows blue. Looks really nice!  8)
Unfortunately I have no pictures of SiC-semiconductors...
Offline Noopy
    • Richis-Lab
« Reply #52 on: June 09, 2020, 03:43:32 am »
Hi all!
Let´s take a look at a newer BUX22!
Well that´s a big heatspreader! It was necessary because the base plate of the package is thinner than the old generation (https://richis-lab.de/Bipolar07.htm).
You can already see the thickness of the metal layer.
The BUX22 makes use of a perforated emitter. The die has a MESA-structure.
And of course second breakdown.  ;D
More pictures here:
https://richis-lab.de/Bipolar08.htm
 :popcorn:
The following users thanked this post: exe, RoGeorge, imo
Online exe
  • self-educated hobbyist
« Reply #53 on: June 09, 2020, 02:43:24 pm »
I wonder why using two dies? As I see, both dies are in parallel without any balansing resistors. They must be very well matched, and, from the secondary breakdown pic, it looks like they are.
I also noticed a few red spots outside where they shouldn't be. I wonder what's that. Like, the one on the right die near the bottom pad.
Offline Noopy
    • Richis-Lab
« Reply #54 on: June 09, 2020, 02:49:24 pm »
Two smaller dies result in a better production yield than one big die.
And with two smaller dies you can use the same die but one for a smaller transistor.  :-+
These are high iso pictures. There are some noise pixels…  ;D
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #55 on: June 09, 2020, 03:53:05 pm »
If a high power die is getting too large, temperature in the center is getting too high compared to the boundary due to limited heat conductance.
Not a problem for a 2N3055, but real for a BUX22.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #56 on: June 09, 2020, 04:57:48 pm »
Not reeeeally... I've seen single MOSFET and IGBT dies bigger than the inside area of a TO-3.  More likely it was contemporary yields.
Don't know what the largest BJT die is, these days; might not even be one as large, just because there's so little demand for them.
Seven Transistor Labs, LLC
Offline Wolfgang
« Reply #57 on: June 09, 2020, 05:23:28 pm »
Same problem with MOSFETs. IXYS uses graded threshold voltages to tackle this problem (high threshold in the center) for their linear MOSFETSs.
All others - same story, with hotspotting in linear mode. See NASA, Spirito Effect.
The following users thanked this post: RoGeorge, Noopy
Online SilverSolder
« Reply #58 on: June 09, 2020, 05:36:59 pm »
We could drill out the remaining pin hole, and get a cheap matched pair transistor? :)
Offline Noopy
    • Richis-Lab
« Reply #59 on: June 09, 2020, 05:40:46 pm »
A very good idea!
I think that´s the ideal input stage for a small earphone amp!  ;D ;D ;D
Offline T3sl4co1l
« Reply #60 on: June 09, 2020, 05:58:59 pm »
The "reeeeally" being, most transistors that size are made for switching, so may have awful SOAs.  The power dissipation is there, no contest, just doing it at voltage is harder.
That said, many newer MOSFETs, and even some IGBTs, are specified with DC SOA.  However they've approached it -- graded threshold, tempco hackery, ballasting*, whatever -- it's done the trick.
*Probably not that, because source/emitter degeneration would severely eat into the saturated performance.
Offline Noopy
    • Richis-Lab
« Reply #61 on: June 11, 2020, 11:56:40 am »
Did you know these small emitter contacts are called "wide-emitter narrow-contact"?
These structures make sure the current is evenly distributed. I assume that´s one reason why it was no bigger problem to connect the two dies in parallel.  :-+
Offline Wolfgang
« Reply #62 on: June 11, 2020, 12:05:31 pm »
Emitter ballasting is actually used, e.g., in high performance audio and, of course, RF power bipolar. More or less all "wide SOAR" stuff. Saturation voltage is of no concern there, and the drop along these resistors does not need to be large to equalize. Linear MOSFETS use the same trick at the source, among others, their RdsON is not as good as their switching cousins for the same reason.
Offline Noopy
    • Richis-Lab
« Reply #63 on: June 12, 2020, 08:21:02 pm »
Today the last one of the BUX22-trilogy:
Yeah, pretty sure a fake.  :--
How did they cut the heatspreader?  :wtf:
Someone has lost a solder ball.  :palm:
Quite interesting MESA-structure!
And here all three of them.
More pictures here:
https://richis-lab.de/Bipolar09.htm
 :popcorn:
Offline duak
« Reply #64 on: June 12, 2020, 09:35:27 pm »
I don't believe I've ever seen two dice paralled as in the BUX22 above.  Looking at a data sheet, I don't see anything calling that out.  I expect the dice are matched before packaging.  Any thoughts on the characteristics that make this possible?  I could see that emitter ballasting would help.
I was thinking of other applications for a dual power BJT that have reasonably matched dice with perhaps the bases and emitters brought out separately.  One thing would be simple current mirror with a current range up to a few amps, but the collectors would have to be electrically isolated from each other.
Offline Wolfgang
« Reply #65 on: June 12, 2020, 09:47:53 pm »
It was common with bipolar RF power parts of the first generation (BLX15, ...)
Its obviously cheaper to have a bigger die when you really command the technology. If you dont,
yield goes substantially down with die size.
Offline Noopy
    • Richis-Lab
« Reply #66 on: June 13, 2020, 06:03:57 am »
I assume this "wide-emitter narrow-contact" technique makes it possible to connect the two dice.
I have heard that the BUX22 can often be seen connected in parallel without ballast resistors. Perhaps the BUX22 is a somewhat special bipolar transistor.  :-/O
Offline Noopy
    • Richis-Lab
« Reply #67 on: June 14, 2020, 08:47:38 pm »
Hi all!
I have started a 2N3055-page:
https://richis-lab.de/2N3055.htm
Last one is a RCA 2N3055H which should contain a hometaxial transistor.
https://richis-lab.de/2N3055_05.htm
The trench following the emitter electrode contains the base-emitter-junction as the pictures of the avalanche breakdown shows.
But I´m not sure about the plateau following the trench. That has to be the emitter material. But why didn´t they design the base feed line shorter? There is no reason for more resistance in the base circuit. Perhaps the manufacturing process was the reason...  :-//
 :popcorn:
The following users thanked this post: exe, Wolfgang, RoGeorge
Offline Noopy
    • Richis-Lab
« Reply #68 on: June 15, 2020, 08:37:13 pm »
I took some more pictures of a RCA 2N3055:
https://richis-lab.de/2N3055_02.htm
I´m pretty sure you can see the difference between the hometaxial and the epitaxial structure:
2N3055H
Here you can see a trench and some "small hills". With a hometaxial construction you have to etch the emitter away to contact the base material.
The surface is uneven because it´s cut or grinded or whatever (mechanical).
2N3055
The surface is very smooth. The reason behind this is the epitactical growth of silicon that gives a much cleaner surface.
  :popcorn:
Offline Noopy
    • Richis-Lab
« Reply #69 on: June 17, 2020, 08:03:44 pm »
Today I have a BD522 for you:
https://www.richis-lab.de/FET01.htm
It seems the metal layer is slightly shifted…
 :popcorn:
Online SilverSolder
« Reply #70 on: June 18, 2020, 02:45:03 am »
The BD522  looks like it's got eyes, LOL!  :D
Offline Noopy
    • Richis-Lab
« Reply #71 on: June 18, 2020, 06:25:44 am »
You are right, didn´t see that!  ;D :-+
Offline Noopy
    • Richis-Lab
« Reply #72 on: June 19, 2020, 05:47:23 pm »
Today a new ST TIP3055:
https://richis-lab.de/Bipolar10.htm
Unfortunatelly the die didn´t survive in one piece but damage is not too bad.
I had only one try…
It uses a perforated emitter.  :-+
Thanks to exe for the part!
 :popcorn:
Online SilverSolder
« Reply #73 on: June 19, 2020, 05:54:13 pm »
What's the thinking behind a perforated emitter?
Offline Noopy
    • Richis-Lab
« Reply #74 on: June 19, 2020, 06:01:49 pm »
You connect the base over the whole die through perforations of the emitter. That gives you a better current Distribution and that leads to lower saturation voltage and second breakdown appears later.
Here you have more perforated emitter:
https://www.richis-lab.de/2SC2922.htm
https://www.richis-lab.de/Bipolar08.htm
The following users thanked this post: SilverSolder, Wolfgang
