Author Topic: Transistors - die pictures  (Read 16170 times)
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #75 on: June 19, 2020, 08:30:30 pm »
You connect the base over the whole die through perforations of the emitter. That gives you a better current Distribution and that leads to lower saturation voltage and second breakdown appears later.
Here you have more perforated emitter:
https://www.richis-lab.de/2SC2922.htm
https://www.richis-lab.de/Bipolar08.htm
Richie,
do you by accident have an 2N2857 at hand ?
I would be curious about this one.
Regards
   Wolfgang
Offline SilverSolder
« Reply #76 on: June 19, 2020, 08:31:59 pm »
Thank you @Noopy, those articles taxed my German vocabulary to the limit, aber es ist etwas gut!
Offline Noopy
    • Richis-Lab
« Reply #77 on: June 19, 2020, 08:43:30 pm »
Hm... Have to take a look at my huge inbox. Got a lot of transistors the last few weeks.  ;D
 ;D Sorry for the german text but english would take me twice the time and I have so much more parts here.  :-/O A HF-Power-Transistor (the big one for GSM stations), a 18Bit-DAC, a 7,5A linear Regulator, a huge opamp and a looooot of smaller but also interesting parts.
I hope Google translator can help a bit and you can ask me here whatever you want.  :-+
« Reply #78 on: June 19, 2020, 08:51:37 pm »
Not a problem, es macht mir vergnugt to read your articles in German (aided by Google if I get stuck)
Offline Noopy
    • Richis-Lab
« Reply #79 on: June 21, 2020, 08:20:20 pm »
Well it´s not transistor but i switches transistors: the gate driver TC4429
https://www.richis-lab.de/TC4429.htm
 :popcorn:
The following users thanked this post: T3sl4co1l, Wolfgang
Offline Noopy
    • Richis-Lab
« Reply #80 on: June 22, 2020, 07:42:38 pm »
Today I have a TIP2955 for you. It´s the complementary transistor to the TIP3055.
https://richis-lab.de/Bipolar11.htm
It looks very similar to the TIP3055 and has exactly the same dimensions.
The perforated emitter looks a bit different. You can see less circles in the "holes" than in the TIP3055. Unfortunatelly I don´t know how exactly the structures are built.  :-//
The TIP2955 came form exe.  :-+
The following users thanked this post: exe
Offline exe
  • self-educated hobbyist
« Reply #81 on: June 22, 2020, 07:59:20 pm »
Thank you very much, this explains why some complementary pairs have very tight parameter matching (e.g., base capacitance). For some reason I expected NPN devices to be smaller for the same power rating. Either this is simply not true, or manufacturing process is well tuned.
Offline Noopy
    • Richis-Lab
« Reply #82 on: June 22, 2020, 08:06:57 pm »
I have often seen mosfets where the p-type is bigger than the n-type. Last time in the TC4429.
I have often seen schematics where the pnp is doubled to achieve the same specifications than the npn.
But as we can see here it´s also possible to design the complementary transistors very similar.
Perhaps it´s a matter of priorities. Perhaps you can design complementary transistors equal but it´s easier to make the "p-type" bigger...  :-//
 :popcorn:
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #83 on: June 23, 2020, 10:20:35 am »
NPN and PNP with similar build (i.e., those will be N and P substrate, then P/N, then N/P, epitaxy or diffusion) have similar properties.  PNP is only like 10-20% lower performance, I've forgotten exactly why now but clearly electrons and holes participate in the same way and mobility is a smaller factor in operation.
Want to say base diffusion is the only step in a BJT where mobility really matters, and the base can simply be made thinner if needed.  If that's the case, we might expect to find stronger Early effect; or, it's further compensated by collector doping profile, with subtle effects on breakdown voltage, Ccb(Vcb) and voltage drop, Idunno.
If a process is limited by shitty (usually lateral) PNP, large areas might be needed to compensate for that.
Complementary MOSFETs will always differ by about a factor of two, because mobility is a direct proportion in their performance.
Seven Transistor Labs, LLC
Offline Noopy
    • Richis-Lab
« Reply #84 on: June 25, 2020, 12:09:00 pm »
Today I can show you a TIP2955 built by ON-Semi:
The die shows a classical construction. It is bigger (2,53mm*2,53mm) than the die in the ST-TIP2955 (2,42mm*2,15mm). I assume that´s because the classical design is less efficient than the perforated emitter design.
A MESA-structure...  8)
 :popcorn:
Offline exe
« Reply #85 on: June 25, 2020, 07:19:14 pm »
Very interesting, thank you. My measurements showed that sy parts are a bit better than onsemi parts in terms of frequency response. Perhaps, due to smaller geometry. I think it's a trend, so I expect all ST bjts will be slightly smaller than onsemi.
Offline Noopy
    • Richis-Lab
« Reply #86 on: June 30, 2020, 08:57:46 pm »
Today I have a SMART-Highside-MOSFET for you: VN02H
Everything on one die. That´s cool but gives you a clamping voltage of only -4V. There are special variants with -18V but that´s still not very much.
(picture taken from application note and modified)
Do you know why integrated SMART-Highside-Driver have low clamping voltages?
There is a parasitic bipolar transistor between the power transistor and the barrier around the logic part that is connected to the ground potential. You don´t need very much voltage to break the collector-emitter-line and kill the part.
The datasheet explains that the overcurrent detection is done with the temperature meassurement (this small satellite) but it seems that there are two small MOSFETs. Theses small MOSFETs can be used to sense the current through the VN02H...
And I have a dead one.  8)
It switched a short circuit.
The ground bondwire acted as a fuse. You can see a colored spot in the transistor area too.
Perhaps there was a overcurrent damage in the transistor and then the rest of the VN02H failed shorting the supply.  :-//
Perhaps there was somehow a transient overvoltage which killed the control part and then the power Transistor died.  :-//
We will never now for sure.
More Pictures here:
https://richis-lab.de/FET02.htm
 :popcorn:
Offline David Hess
  • DavidH
« Reply #87 on: July 01, 2020, 02:01:25 am »
I assume the dielectricly isolated process used for DMOS would be too expensive in both fabrication and area.
That is a very common technique for CMOS power devices and 4 pin power MOSFETs which allow monitoring the current.  A few cells of the power MOSFET have a separate drain connection brought out and the ratio of areas determines the fraction of the drain current which is detected.
It also works for bipolar devices.
Online T3sl4co1l
« Reply #88 on: July 01, 2020, 02:17:18 am »
Wow, surprised they waste so much die area on control logic!
Offline David Hess
  • DavidH
« Reply #89 on: July 01, 2020, 02:35:12 am »
An LM395 die shot would be interesting and I think I have seen it somewhere.  As I recall, it was very similar to the LM317 and might have been the same die with a different metalization.
Offline Noopy
    • Richis-Lab
« Reply #90 on: July 01, 2020, 03:12:22 am »
And with dielectric isolation you can´t build the more powerful vertical DMOS, can you?
I know this kind of current measurement. It just surprised me that the datasheet by contrast explains a temperature based overcurrent detection.  :-//
I will put the LM395 on my to-do-list.  :-+
Offline David Hess
  • DavidH
« Reply #91 on: July 02, 2020, 02:50:18 am »
No, I don't think you can but the lateral power devices can still be very powerful.  Their disadvantage is that they take much more area.  On the other hand, they have much lower capacitance.
Offline Noopy
    • Richis-Lab
« Reply #92 on: July 02, 2020, 03:36:07 am »
Well, you are right.  :-+
Offline Noopy
    • Richis-Lab
« Reply #93 on: July 05, 2020, 07:31:17 pm »
Hi all!
Today I have a BD911 for you. It is quite simliar to the TIP3055 (https://richis-lab.de/Bipolar10.htm). The collector-emitter-voltage and the hfe are a bit higher for the BD911.
The die is similar to the die in the TIP3055 but it´s smaller (4,66mm² vs. 5,25mm²) although it has the better specifications.
In my view ST was able to enhance the specificatons of the stackup. Probably the more close meshed perforation improves also the specifications.
I think they did some potential steering in the corners of the die.
The perforations are quite small compared to the TIP3055.
https://richis-lab.de/Bipolar12.htm
Part was donated by exe.
 :popcorn:
Offline exe
« Reply #94 on: July 05, 2020, 08:16:49 pm »
Very interesting, the die is smaller, however it looks like the "labyrinth" has more total length. I wonder which one has less parasitic capacitance.
Anyway, which one would be prefered for a linear power supply and why? :)
Offline Noopy
    • Richis-Lab
« Reply #95 on: July 05, 2020, 08:30:03 pm »
My read is that the BD911 has less capacitance.
Less area => Less capacitance.
But perhaps the SOA of the BD911 is smaller. A smaller die is often heavier donated. But that´s only a guess…
Hard to decide which on is better for a linear power supply. BD911 has a higher voltage rating but perhaps TIP3055 has a bigger SOA...  :-//
Offline Noopy
    • Richis-Lab
« Reply #96 on: July 06, 2020, 07:08:37 pm »
Today I have an old TIP3055 built by TI:
The mold compound is very persistent...  :-/O
A classical mesa-design but OnSemi uses it still today for the TIP2955:
https://www.richis-lab.de/Bipolar11.htm
You can find the TIP3055 overview here:
https://www.richis-lab.de/Bipolar10.htm
 :popcorn:
Offline David Hess
  • DavidH
« Reply #97 on: July 08, 2020, 12:39:17 am »
I was under the impression that the mesa process was long discontinued, except maybe for premium parts, because it is too expensive due to the time it takes to manufacturer.
Offline Noopy
    • Richis-Lab
« Reply #98 on: July 08, 2020, 02:31:10 am »
Perhaps it´s still cheaper than for example manufacturing a perforated emitter?
Perhaps there is an old production line working at a very reasonable price?
Offline Noopy
    • Richis-Lab
« Reply #99 on: July 12, 2020, 08:03:56 pm »
Today I have a very special transistor, the Programmable Unijunction Transistor 2N6027:
The die is very small: 440µm x 440µm.
However for 10µs a peak current of 5A is allowed.
These transistors are still in production.  :-/O
The following users thanked this post: SeanB, exe
