Author Topic: LED Strobe Light  (Read 1534 times)
Offline nes999Topic starter
LED Strobe Light
« on: January 08, 2017, 01:49:38 am »
I want to make a box with a few different colored LEDs for a special needs family member. This is my first time dealing with small electronics.  I am having a total of 32 LEDs. The most on at one time is 16. However there will be rapid flashing between colors.
 Do I plan for enough power for all 32 LEDs or for the max of 16 that will be on at one time?
If it matters I am using an arduino to control the flash patterns.
« Last Edit: January 08, 2017, 02:12:43 am by nes999 »
Offline ebclr
Re: LED Strobe Light
« Reply #1 on: January 08, 2017, 02:09:09 am »
In the worst case scenario 500 ma will be enought, but probably you will be in 200 ma range
Offline ajb
« Reply #2 on: January 08, 2017, 06:00:02 am »
There's no need to design for conditions your device is never expected to see.  Whether your expected conditions are accurate to the intended usage scenarios is another question, though.  "Rapid flashing" isn't a concern as long as one color is turned off before the other color is turned off, but even a brief period of both being on may be able to be covered by bulk capacitance.
What sort of LEDs are we talking about here?
Offline BrianHG
« Reply #3 on: January 08, 2017, 01:28:58 pm »
For my recent flashing led project, I used this cheap SOT-23 mosfet: BSS806N H6327 which I drove right from my PIC's IO with a gate drive of 2.5v or above, and had a series resistor to the power LED I was using.
Though in my case, I was sinking a 2 amp pulse to strobe illuminate a room, you will only need to use a fraction of that with normal LEDs.
« Reply #4 on: January 08, 2017, 05:30:18 pm »
Attached below is the full data sheet for the ones I bought.
I know those are really bright, However what they are using now are construction strobes and I'm afraid if they want from that level brightness to a dimmer LED he will not use it. I figured I could make this, and if it works try making a dimmer one also.
I'm really glad to see that I only have to have the battery sized for what's on at the moment. That means I only need to supply it with a 12v battery source, and of course appropriate resistors.
http://cloud.tapatalk.com/s/587275821a089/YSL-R531Y2C-A13.pdf
