You're asking the wrong question in part; which makes this an X-Y problem, but in a conveniently short form (most likely).
Namely-- you're getting digital noise, because your analog input is noisy (or the comparator is unstable for a variety of reasons). Why not filter that first?
It is a
very good idea to use
only as much bandwidth as you need. This doesn't mean you need filters at every single stage of your system; for any given chain of stages (say of amplifiers), it's okay to filter...usually the input, but the output may need filtering due to noise picked up in those stages.
What delineates a "chain of stages" is, when they're linear. This is a required assumption: ignoring noise, any combination of linear stages and filters can be placed in any order, with no effect on the overall response.
Where you need a nonlinear function (like a radio mixer, or a digital converter like a comparator or ADC), that assumption is broken, and filtering matters more. In addition to separating signal and noise, there are harmonics and IMD and reflections and whatnot that nonlinear stages are prone to generate, which you may need to filter out between functions.
So, that's a very high level setup, but it simplifies in your case down to simply, whatever the input circuit is (filtering, limiting/protection, buffering, amplification), whatever it's attached to (the comparator), and wherever that goes (what's the digital signal being used for, how much time delay can it tolerate, etc.).
You can indeed make a timed-lockout comparator; more generally, you can make a variety of digital filters, which can to some extent patch up noise like you see here. But it's not a good general approach, because in the digital domain you have no idea whether the input is noise around zero crossing and therefore should be ignored, or if it's actually the signal going bonkers and you should probably respond to it somehow! Those are factors that you really need to handle in the analog domain, or at least with more digital bits, or a much higher sample rate and dithering.
A typical solution is sampling the digital value periodically, incrementing or decrementing an accumulator with saturating arithmetic, and setting the final output only when the accumulator value is above or below a threshold. That is (in C),
#define MAXVAL 7
#define RISING_THRESHOLD 5
#define FALLING_THRESHOLD 2
bool input, output = 0;
int accum = 0;
// input is 0 or 1 (limit or mask accordingly)
accum += input * 2 - 1;
if (accum < 0) accum = 0; else if (accum > MAXVAL) accum = MAXVAL;
if (accum > RISING_THRESHOLD) output = 1; else if (accum <= FALLING_THRESHOLD) output = 0;
Note that this has a delay of RISING_THRESHOLD samples going up and MAXVAL - FALLING_THRESHOLD going down, with hysteresis of RISING_THRESHOLD - FALLING_THRESHOLD.
The implementation of this in logic is better (just throw it in a few FPGA cells), and doesn't cost any CPU cycles to compute of course. Wouldn't recommend making it in discrete logic; the analog timed version (digital input as constant current charging a capacitor; window comparator and flip-flop sets output) will be easier.
As for what you originally asked for (a timed holdoff) -- that can be made in very much the same way. You want to, let's see (excuse me as I synthesize on the fly) -- probably an R-S f/f for output, and R/S pulses are generated when the input and output differ in state, but masked by an AND gate tied to a monostable.
Or for an analog solution, you could have some maximum input rise/fall time requirement, then detect the current flowing through an analog switch; the current is rectified so a trigger is generated for either polarity. The switch feeds a small capacitor, so when the input changes state, a current pulse is drawn, and this triggers a timer which controls the switch. So the switch opens and the capacitor retains state while the timer runs. Downside: the output oscillates at (2/delay) frequency if the input is chattering at the moment the timer runs out.
