Author Topic: Trouble bridging HDMI to DSI using TC358870XBG  (Read 1521 times)
Offline tardiGrade98_Topic starter
« on: December 21, 2020, 05:28:47 pm »
Hello,
For a while now I have been attempting to drive a MIPI display using my own firmware. As far as I can tell, the setup for the screen is successful, it asserts OLED_EN, and communicates the correct EDID data to the source, and yet no images show on the DSI panel. All I get are the white horizontal lines you can see on the picture I attached. The screen came with a driver board and was working out of the box. But I need to replicate the factory Firmware. I sniffed the I2C packets between the MCU (STM32) and the Toshiba HDMI-MIPI bridge (TC358870XBG), from there I reconstructed the setup file for the TOS chip and the panel, but instead of showing bridged images from the HDMI source, I get the white horizontal lines. Has anyone been in my situation, or had similar issues with a MIPI panel before?
Display: https://www.aliexpress.com/i/4000192657266.html
Regards,
Offline vitalic66
Re: Trouble bridging HDMI to DSI using TC358870XBG
« Reply #1 on: October 09, 2022, 02:07:42 pm »
Have you ever been able to fix this?
I also need a special FW to drive a special display with other resolutions.
Regards
Offline dajanchar
  • Country: si
    • NanoVision
« Reply #2 on: December 25, 2022, 03:25:39 pm »
Hello,
I have ordered a round LCD display from china, where I have similar issue. The LCD and HDMI-MIPI board were ordered separately, which I presume is the issue because the LCD display is not working. HDMI link is detected OK (based on green LED), however only backlight of the LCD is enabled. I have also dumped I2C traffic and so far, everything looks OK regarding configuration itself. Basically the board configures HDMI-MIPI bridge to use both MIPI channels.
If you want we can connect on some chat and discuss the issues further in more technical manner. I can provide my version of FW / I2C configuration so you can test it for yourself.
