I need to replace a couple of resistors in my headphone amp as they were fried when trying to use the amp to power small loudspeakers
The original resistors are Dale 20 Ohms 1% T9 CMF55 0541.
I bought two models with identical resistances but with different temperature coefficients 100 vs 50 PPM.
The new ones have slightly different markings on them instead of T9 they're either T1 or T2 I assume this is for the different temp coeff. as mentioned above.
That being said however, I have no clue what the original T9's specs areas i could not find its datasheet.
Would it be ok to use either one
