I have a SST39SF040A (512K x 8 ) flash which I am trying to program and it is misbehaving.... some bytes seem to stick whereas other ones don't work out...
If I program...
I intended to program...
00004000 : 1D C7 48 C6 35 CC EF C7 C5 CA DF CA 70 CF 23 CB 9C C8 9C C7 74 C7 1F C8 0C C7 7F C7 C9 C7 32 C8
00004020 : 1B C7 42 C8 01 D7 D4 FF D7 FF DA FF 94 D2 F8 D6 7E C9 9E C9 44 C7 A7 C5 6F C7 84 C9 DD FF BF FF
00004040 : C2 FF 9E CA 50 C5 0B DB 9E DB 2A DB 00 00 64 D2 85 D2 24 DE 45 DF BF D8 A0 DE 9E DF A5 DF EE DF
00004060 : 48 E0 E6 D6 54 D6 49 D3 85 D6 63 D6 C4 D5 D8 D5 04 D6 0F D6 79 3E D7 79 27 D7 7B FF D8 7B E3 D9
00004080 : 7F 2D DE 50 D8 CE 46 D5 CE 7D 66 DE 5A E7 CD 64 05 CF 45 4E C4 46 4F D2 4E 45 58 D4 44 41 54 C1
then when verifying (* means mismatch)
00004000 : 00*C7 40*C6 15*CC EF C7 84*CA C0*CA 60*CF 02*CB 8C*C8 8C*C7 04*C7 0F*C8 0C C7 0F*C7 C9 C7 02*C8
00004020 : 1A*C7 42 C8 01 D7 D4 FF D7 FF DA FF 84*D2 00*D6 0A*C9 8A*C9 40*C7 A4*C5 66*C5*80*C9 DD FF BF FF
00004040 : C2 FF 1C*CA 50 C5 01*DB 98*DB 20*DB 00 00 40*D2 00*D2 04*DE 45 DF B6*D8 80*DE 98*DF 85*DF 28*C0*
00004060 : 08*E0 E0*D6 54 D6 09*D3 85 D6 61*D6 C4 D5 D8 D5 04 D6 01*D6 79 34*D7 79 25*D7 7B 36*D8 7B 01*D8*
00004080 : 7F 25*DE 50 C8*CE 46 C5*CE 7D 20*DE 5A C6*CD 64 05 CE*45 4E C4 46 4F D2 4E 45 58 D4 44 41 54 C1
So some bytes are correct... in fact some runs of bytes are correct... but some are not!
My current code, with some defensive delays, is...
void flashProgramByte2(ADDRESS_T address, uint8_t data) {
// Check FLASH is very off
nOE_Set();
nCE_Set();
nWE_Set();
setDataForWrite();
setAddress(0x5555);
writeData(0xAA);
nWE_Clear();
nCE_Clear();
// TWP 40ns
SysTick_Wait1us();
nWE_Set();
nCE_Set();
// TWPH
SysTick_Wait1us();
setAddress(0x2AAA);
writeData(0x55);
nWE_Clear();
nCE_Clear();
// TWP
SysTick_Wait1us();
nWE_Set();
nCE_Set();
// TWPH 40ns
SysTick_Wait1us();
setAddress(0x5555);
writeData(0xA0);
nWE_Clear();
nCE_Clear();
// TWP
SysTick_Wait1us();
nWE_Set();
nCE_Set();
// TWPH
SysTick_Wait1us();
setAddress(address);
writeData(data);
nWE_Clear();
nCE_Clear();
// TWP
SysTick_Wait1us();
nWE_Set();
nCE_Set();
// TBP 20us
for (int i=0; i<20; i++) SysTick_Wait1us();
The wait at the end should be sufficient (matches datasheet) and in reality my program then does some serial IO for the next byte so there is a huge delay between calls. This is running at 48MHz on a ATSAMC21G18A and 1/f gives 20.8ns per instruction if it were one cycle... so nothing can happen faster than that.
Very confused.
Thanks in advance
