Author Topic: Measuring light reflection in very tight space.  (Read 684 times)
Offline eTobeyTopic starter
    • Virtual feature script
« on: May 14, 2023, 05:44:10 pm »
i have to measure the reflection of a disc, but i dont know, how i can properly align the LED to the phototransistor. The LED does not distribute the light at 180° degrees with an even intensitiy (see the picture). Anyone has an idea how to get some good illumination?
Cheers
Toby
« Last Edit: May 14, 2023, 07:35:31 pm by eTobey »
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
Offline Twoflower
Re: Measuring light reflection in very tight space.
« Reply #1 on: May 14, 2023, 06:24:26 pm »
You can just by a ready made device like this: ELI TR9904 Reflexlichtschr 3,0mm PCB-Mt
Not sure how strong the sensitivity falls off if you reduce the distance below the focal point (the device above has a working distance of 3mm).
Edit: Just noticed Reichelt mentioned the package weight in scientific notation  :-DD
« Last Edit: May 14, 2023, 06:30:43 pm by Twoflower »
« Reply #2 on: May 14, 2023, 06:48:29 pm »
This is waaay to huge, but i also found some smaller ones of this kind. But now i wonder, where the center point of detection is. Is it in the middle of the two elements, or just under the phototransistor?
With my seperate elements, i was thinking about how i could put the LED in a slight angle, to fully iluminated the surface under the phototransistor.
« Reply #3 on: May 14, 2023, 06:57:34 pm »
I found another funny thing:
I wonder if this part is good, when the datasheet is already kinda funny.
Offline Twoflower
« Reply #4 on: May 14, 2023, 07:03:17 pm »
Your picture showed the 1...3mm form the top of the photo-transistor no limitation of the sensor dimensions ;-) But yes there are also SMD types (e.g. GP2S700HCP). The GP2S700HCP datasheet has also a diagram showing the relative sensitivity over distance. The 1mm is probably to close.
I would assume that both emitter and receiver are looking inward that the sweet-spot is aligned to the center of the device.
« Reply #5 on: May 14, 2023, 07:39:05 pm »
I have read a few times those elements "facing the same directions" or "both are in the same plane". So it would look like in my drawing. I just ordered one, and i will investigate. :-/O
