Author Topic: Trying to figure out a motor control circuit which has a Triac.  (Read 1055 times)
Offline YaminTopic starter
  • Country: mv
Hi, I'm tracing a motor control circuit of a coffee grinder. Nothing is broken just doing it for educational purposes. I do not understand how the following resistors and capacitor is connected and its purpose, it doesn't look right to me as I have not seen it like this before. I am assuming its the snubber circuit.
Where is the neutral connection coming into? :S. I haven't continued tracing the rest of the circuit yet. I'm stuck at this point trying to figure out whats happening here. Maybe I'm drawing it in a way that is confusing...
The motor is an asynchronous motor.
Thanks in advance for the help
  • Country: mv
Re: Trying to figure out a motor control circuit which has a Triac.
« Reply #1 on: April 20, 2019, 06:14:59 pm »
I have drawn the other part of the circuit (not the gate connection though) and I'm afraid its even confusing more :(
Offline soldar
« Reply #2 on: April 21, 2019, 08:21:22 am »
It has a speed control knob? My guess is that it is a triac phase control and the transformer supplies low voltage to some kind of control circuit.
The following users thanked this post: Yamin
Offline mikerj
« Reply #3 on: April 21, 2019, 09:24:18 am »
I suspect the main problem is that you've drawn it in a particularly confusing way.   The X2 cap and 39k resistor are connected right across the triac in a classic snubber configuration, but that isn't immediately obvious from the diagram as drawn.  The 180k is a bleeder resistor to ensure no charge remains on the snubber after power has been removed.
Offline soldar
« Reply #4 on: April 21, 2019, 09:54:01 am »
Have a look at this thread and you can reverse engineer the circuit.
https://www.eevblog.com/forum/beginners/pcb-to-scheme/
  • Country: mv
« Reply #5 on: April 27, 2019, 08:14:30 am »
Thanks everyone for the response guys. I came across this explanation about Triacs at https://www.nutsvolts.com/magazine/article/triac_principles_and_circuits_part_1
It has got some similarities for the circuit I have drawn. Could this be it?
