tl;dr: Trying to figure out what this connector is. It's a bit bigger spacing than XLR. Only 2 of the pins are wired, the third pin is a dummy. I don't have it on my bench yet but I was told the measurements were " Pin dia 2.90 mm, motor pos to neg pins center to center 11.20 mm, the other dim 7.25 mm" I also created a collage of different angles of this connector in hopes it may help ID it. Perhaps it is proprietary or?
Pics attached below, hi-res versions hosted here:
https://imgur.com/a/CC0M11FFull post:
I'm wanting to power a blower motor with a usb power bank instead of the original 4.9-5v 2A NiCd batt that it was designed to use. I was hoping to avoid altering the blower motor and instead use an adapter to convert the blower's connector to a USB2.0 male so I could insert it into a power bank.
I don't have the blower in my hands yet, was hoping to have all the parts ready and waiting for it when it arrives but I hit a snag. Does anyone happen to know if this type of connector has a name? I thought it was XLR at first but then was told by the person giving the blower to me that the dimensions on the pins were " Pin dia 2.90 mm, motor pos to neg pins center to center 11.20 mm, the other dim 7.25 mm." which sounds a bit bigger than an XLR. Any clue if this may just be proprietary or am I overlooking an obscure connector?
