Author Topic: Which chip is in this project .. ?  (Read 747 times)
Offline wissaTopic starter
« on: January 27, 2020, 07:18:17 pm »
Hi, I came up with this product which I am interested in doing a similar one ... Do you have an idea which chip is in there or could you advise on a buck-boost converter with IN:1-30V and OUT:0-30V if possible with current cabability of 1-2A ??
Here is the link of the product
http://www.icstation.com/adjustable-step-step-down-power-supply-module-buck-boost-voltage-converter-p-13462.html
or
http://www.icstation.com/adjustable-step-down-power-supply-module-buck-boost-voltage-converter-p-13542.html
Regards,
Offline AE7OO
Re: Which chip is in this project .. ?
« Reply #1 on: February 14, 2020, 01:05:22 am »
Greetings,
The controller is a Feeling Technology FP5139 which is used with a NCEPower NCE6075 NFet.
There is also going to be a meter chip controlling the LED display, but those are fairly easy to come by.
I've included datasheets for both chips,
I found a review of board using the  FP5139 https://www.eevblog.com/forum/reviews/30w-sepic-dc-dc-converter-review-(5-35v-in-0-8-35v-out)/
 It's obvious from just the component selection alone that whoever "designed" it, did not have a clue. ON the other hand, it looks like whoever did the ZK-DP2 knew just a little bit more...  :-+
Unlike the other board's 30W rating the ZK-DP2 only has a 15W rating, but it has a lot of adaptability and is not a design from the datasheet(I've only got two though) >:D
I've found out that yes, they still sell them and found an app note which I've also include now.
« Last Edit: February 14, 2020, 01:54:37 am by AE7OO »
