Author Topic: Tubular extruded heatsink manufacturer  (Read 1055 times)
Offline OgreVorbisTopic starter
« on: June 13, 2019, 03:23:36 am »
I'm looking for a company that sells heatsinks like this: https://www.fischerelektronik.de/web_fischer/en_GB/heatsinks/D02/Miniature%20cooling%20aggregates/$catalogue/fischerData/PG/LAM4/search.xhtml
I would go with fischer, they just don't have the length I need and I'd like the raw stock anyway.
I don't know the exact term to describe this other than tubular extruded heatsink.
Let me know if you know any manufactures for this.
Thanks.
« Last Edit: June 13, 2019, 03:25:56 am by OgreVorbis »
Offline soldar
Re: Tubular extruded heatsink manufacturer
« Reply #1 on: June 13, 2019, 06:16:41 pm »
Interesting concept. I have never seen those in the wild. Maybe the purpose is to exhaust the hot air into ducts and then take it away?  Otherwise I cannot think of a reason to use them.
Maybe you can ask https://www.boydcorp.com/thermal/heat-sinks/extruded.html
Offline Benta
« Reply #2 on: June 13, 2019, 06:50:46 pm »
Why don't you call Fischer?
I'm pretty certain that the extrusion tool is their property, but that doesn't mean they won't sell the profiles in full length.
Offline wraper
  • Country: lv
« Reply #3 on: June 13, 2019, 06:53:26 pm »
They are common in electronic loads and system PSUs. You can mount a lot of devices on both sides, and all hot air gets straight out from back of the case. Great for dissipating a lot of heat.
« Last Edit: June 13, 2019, 06:58:23 pm by wraper »
Offline thm_w
  • Non-expert
« Reply #5 on: June 13, 2019, 10:52:59 pm »
If you are making a lot of these, its not too expensive for a custom die. But if 40x40mm works thats quite a standard size so you should find something that works.
https://www.aliexpress.com/i/32821793383.html
https://www.aliexpress.com/i/32780223588.html
https://www.aliexpress.com/i/32904858135.html
https://www.aliexpress.com/item/1-piece-4CM-fan-radiator-Aluminum-profile-cooling-tunnel-40-40mm-Length-can-be-customized-free/32913499568.html
Thanks so much. That's the exact size I'm looking for.
I called fischer and they gave me a quote for custom and the price wasn't as bad as I expected.
