I dont think it will be that easy, you have hacked some feedback for the control smps ic`s, but normally they have some values range in their feedback to add tolerance for the ovp protection if any implemented.
The tl431 or any variant is normally used in the feedback loop, not has the main regulator, it drives the feedback optocouplers to the main smps chips
you have to search the 4800 ic`s specs and see what can you hack, sometimes disabling the ovp may help, but you`re loosing some protections too, unless you really know what you`re doing, i would not mod this, use a variable linear regulator at the output instead.
Your modification link point to an based tl 494 smps ic, theses are more easily modifiable, there is some google projects too, an 0-50vdc variable smps based on it.
