Author Topic: What type of connector is this?  (Read 4105 times)
Offline graffiticiTopic starter
« on: July 14, 2014, 04:42:32 am »
Hi all,
I'm trying to build a PCB that can interface with the SeeedStudio Grove system. Essentially, I need a connector that looks exactly like this:
http://www.seeedstudio.com/depot/Grove-Universal-4-pin-connector-p-789.html
The one they are selling is out of stock (and is a bit overpriced). Does anyone know what type of connector that is?
There is a discussion in the comments about the "TE Connectivity 1735446-4", but apparently it doesn't fit?
Thanks!
Offline Psi
Re: What type of connector is this?
« Reply #1 on: July 14, 2014, 04:59:49 am »
For people that cant be bothered clicking the link and zooming in..
Offline miguelvp
« Reply #2 on: July 14, 2014, 05:13:06 am »
doing a simple google of the sku: ACC39145O
returned hits.
http://www.epictinker.com/Grove-Universal-4-Pin-Connector-p/acc39145o.htm
Is one of them in stock at $1 for 10 of them.
Description:
Grove - Universal 4 Pin connector is the white 4-pin buckled connector used on Grove modules and cables.  The pin spacing is 2mm. There are 10 connectors per bag, handy for making your own Grove boards.
There are others as well, this was the first hit.
Edit: the original listing is $0.90 for 10 of them so 9 cents per connector, I wouldn't call that overpriced ;)
« Last Edit: July 14, 2014, 05:16:06 am by miguelvp »
« Reply #3 on: July 14, 2014, 06:09:35 pm »
Thank you both! I didn't realize the original listing was for 10 units. That's indeed a very good price, if only they could keep them stocked!..
Offline TheBorg
  • Hoping to start an EE degree soon...
« Reply #4 on: July 15, 2014, 02:16:06 am »
FWIW looks like a 2mm JST connector
Youtube Channel - Assimilated Circuits
We are Borg. You will be assimilated. Resistance is futile.
Offline Mr.B
« Reply #5 on: July 15, 2014, 04:20:27 am »
TheBorg is correct.
It is a 2mm JST.
I have purchased them from Seeed before.
They are a lot cheaper from Seeed than Mouser/Digikey.
Not being in stock makes it a bit difficult.
Offline Richard Crowley
  • KJ7YLK
« Reply #6 on: July 15, 2014, 05:19:07 am »
As it appears to be a standard JST connector, there seem to be many alternate sources.
Since graffitici has not revealed a location, it would seem pointless to try to recommend any particular sources.
Offline Monkeh
« Reply #7 on: July 15, 2014, 07:29:29 pm »
If it's a JST part, which series is it?
