Apples secret....
Have you ever wondered about why sometimes when you use an unofficial Apple charger, the device says "Charging Not Supported with this Accessory" when in fact... it sometimes still charges?
Or do you know why some outside chargers don't charge all together?
It has to do with the USB. USBs work because they have 4 pins - 1 for the 5V power, 1 for ground, and two for data (D+/D-).
When you use non-Apple devices and plug them into the wall or the computer, these devices are made for the standard 5V that comes standard with most USB cables. What happens is that if you are using the USB solely for power, the device will ignore the two data pins - the D+ and the D-. In that case, it works like any other wire... as it should.
With Apple devices, it's different. The engineers at Apple have made the process a bit more complicated.
For example, when you plug in an iDevice into a wall plug, the standard 5V and grounding still applies... but the device still uses the other two cables...
The Secret Sauce
While most devices ignore the D+/D- cables when only utilizing the USB for power, Apple devices use the D+ and D- as communication cables. The Apple cables have resistances on them (if you recall, resistance controls the Voltage and Amps). The resistances tell the Apple device what it's connected to and in return tells the device how much power to draw. This means that voltage still needs to run across the D+ and D- pins!
This is a cheap way for the Apple device to "guess" what it's connected to. ::)For example, if it thinks it's connected to a wall charger, it will draw more power and thus charge the phone quicker (usually at 1A). If the device thinks you're connected to the computer, it will draw less power (usually at 0.5A) and thus will take longer to charge. The resistances thus are the signals that tell the iDevices what to do.
This neat little trick by Apple has 2 main consequences:
You can trick the charger into charging at different rates (faster or slower) by tweaking the resistances on the data pins
A well-designed charger for Apple devices will take these resistances into consideration
Check out this video about Apple's Secret Charging Methods.
Hunor
