So I checked if I can find any of the compatible irons but unfortunately there was no used one for a cheaper price. I guess I'll have to save up to get one but since I only had to pay 5€ on the scrapyard for the station that should still be a good deal for a Metcal. I always wanted one again.
Thank you for the help.
Greetings
Marco
Five bucks is a great price indeed
Keep an eye on "metcal" and "metcal smtc" on eBay. Very often you can get tips for the MX system for cheap (the PS2V uses the same tips as the MX). STTC are the "normal" ones, "SMTC" are "specialty" tips, like for SOIC packages, SMD chip packages like resistors and caps, large blades, etc. Sometimes you can get a bunch of NOS tips for cheap, like 5 SOIC tips, new old stock, for like 25 dollars or so. Either resell the excess or share with friends that also have a 13.56 Metcal (or compatible)
Greetings,
Chris
Edit: And see to it that you get mostly the SMTC or STTC 1xxx tips. They work just fine for leadfree and leaded, as well as on larger copper areas. They rae the 700°F/370°C version. The 0xxx are the 600°F/315°C variant. While they work OK for most stuff as well, they can sometimes be insufficient for larger things like heavy groundplanes in multilayer boards, etc.
